Discussion about Automix Cues
geposted Tue 04 May 21 @ 3:14 pm
Can you break down what each one means? Trying to figure out which one sets the intro mix of a song and which one sets an outro mix for a song?
geposted Sat 17 Jul 21 @ 4:50 am
Nice Plugin. but what exactly does every pad do?
geposted Sun 25 Jul 21 @ 1:44 pm
Doesnt seem to be working, nothing is getting set...
geposted Sat 02 Oct 21 @ 1:01 am
Does not work and VDJ should take this out from extension since no response from the developer. But overall decent idea
geposted Sat 06 Jan 24 @ 8:44 pm
It works fine, to see what is set you need to open the poi editor.
geposted Sat 06 Jan 24 @ 9:02 pm
In order to make the mixpoints visible in the timeline with white triangles ▼
you can also edit the related "database.xml".
With text editor or free command line tools like FindAndReplace
you can add for example for realstart and realend:
" Num="-1" is the same as setting point type cue to "Marker only" in the poi editor.
In a 2nd step you have to replace all doubled (Num="-1" Num="-1") with single (Num="-1").
This is more convenient than using the poi editor for all songs to get visibilty of mixpoints.
Find what: " Type="automix" Point="real
Replace with: " Num="-1" Type="automix" Point="real
geposted Mon 24 Feb 25 @ 3:45 pm
