hello
im using VDJ 2021 in a laptop with windows 10 with a RMX controler.
I'm having problems saving the remaping of some key buttons on the RMX.
When i change the buttons and knobs to apply what i want i dont have the save hability and when i close the program and open again it doesent save anything.
I can only modify what i want without exiting VDJ, can somebody help me please?
I see a little "disk" there in the remaping options but i click it when i remap something and nothing happens. (see the picture above)
Thanks in advance.
Thanks in advance.
geposted Fri 07 May 21 @ 10:01 am
Just click the X at top right corner, and you will get asked if you want to save
geposted Fri 07 May 21 @ 11:55 am
Yes but when I shut down Vem and restart it doesn't save what I choose before...
geposted Fri 07 May 21 @ 3:34 pm
Strange .. .should..
Did you copy over the mappers from other computer and some write permission thing perhaps?
geposted Fri 07 May 21 @ 4:03 pm
No no i did not copy anything,i made a first install of VDJ after i format my laptop a couple weeks back.
I don't know what else to try,any other suggestions please?
Thanks for the help
Thanks for the help
geposted Fri 07 May 21 @ 6:23 pm
