FILTER FOLDER
in filter folder only export browser view is possible
the new export function is not integrated
VIRTUAL FOLDER
both are possible in virtual folder
export Browser view and the new export function
VIRTUAL FOLDER
geposted Sat 08 May 21 @ 8:41 am
Export is for playlists currently..
A filter folder is different, its not a playlist rather its a search result.
You could drag and drop the result of a Filter to a playlist.
Maybe in future updates also filters can be exported as if they were a playlist....
its a different type of thing though, and just a "current view" of sorts. Some filter folders will even change content to what you play etc..
geposted Sat 08 May 21 @ 10:46 am
But warn, currently
- playlist defined as favorite does not allow export
- Export is only available for playlists from Tree View, but not from Sideview menu
geposted Sat 08 May 21 @ 11:06 am
Favorite is just a bookmark to a folder on a drive. So also not a playlist.
Initially the "new" export was made with CDJ export in mind, being a playlist export function..
But who knows, maybe in update the "current view" can be exported (or not.. ).
geposted Sat 08 May 21 @ 11:41 am
