When doing simple baby scratches with the FLX6 the sound is not clean but I get a lot of hiccups, e.g. when just scratching in the middle of a simple "Ahhh" sample, I get a lot of "clicks", instead of just continuous sounding scratches.
I tested my Traktor Kontrol S2 MK2 and this behaviour was not replicated.
I checked that my signals in VDJ are not clipping, I also turned off the mathengine, I used the soundcard of my computer, the soundcard of the FLX6 and nothing has resolved this problem.
So any help with this problem is very appreciated.
Thank you :)
PS: I also used the FLX6 with Algorridim Djay and no problems at all with scratching
Thank you :)
geposted Tue 11 May 21 @ 3:07 pm
Also tested Rekordbox 6 and no problems with scratching
geposted Tue 11 May 21 @ 6:38 pm
