Topic: Asio driver error
My friend just downloaded vdj pro. Has an sx3 ising a PC. Virtual dj is giving him an asio error and nothing is playing. I’m thinking he needs to download asio4all?
geposted Thu 13 May 21 @ 5:17 pm
He should use the default Pioneer asio drivers..
The error is most likely because Windows took the SX sound card as its own default sound card, and hence already taken when VirutalDJ try initialize the asio.
Set Windows to use the PC sound card instead:
https://www.tenforums.com/tutorials/102323-change-default-audio-playback-device-windows-10-a.html
And if that was not it, make sure the SX3 routing is correct in VirtualDJ sound settings
https://virtualdj.com/manuals/hardware/pioneer/ddjsx3/setup.html
Thank you rune but I'm still getting the same asio error. I can turn the dial to load a song but when i move the crossfire effects knobs i get no movement on the screen. My pc is hp envy360. I can run this controller with serato no problems but I want to use the advanced features and broadcasting from VDJ.
Not sure what crossfire effect knobs are..
But when you play a song everything works except the crossfader?
