I used virtual dj with my numark recently with no isuues. I recently bought a pioneer sx3 and I wanted to use VDJ instead of serato for the advanced featues. All my friends are using this with no issues. I can not get the VDJ to work with my new sx3. It keeps saying ASIO drivers error. I've had friends try to help me with everything possible and no luck.
geposted Thu 13 May 21 @ 6:35 pm
Does it works in wasapi mode ?
ASIO is not always a good idea, specially with other ASIO installed
geposted Thu 13 May 21 @ 6:53 pm
Using the same controller myself, works perfectly ;-)
Did you install drivers?
https://virtualdj.com/manuals/hardware/pioneer/ddjsx3/setup.html
And follow the setup guide? fairly straight forwards and easy though
And did you set the switches to usb A on the channels?
Its just some minor overlook, cause this controller is used by tons of VDJ users, one of the more popular ones ;-)
geposted Thu 13 May 21 @ 6:55 pm
Can also contact Support here for remote help:
https://virtualdj.com/help/
geposted Thu 13 May 21 @ 7:18 pm
