I have to check many songs. To know which already checked, I want to use the comment (in my Tag-Editor looks like "Kommentar" Maybe "User1" or "User2" would be better...
In this field shall appear "checked 21"
Now I want to map a key to do this job without opening the Tag-Editor.
This would save me a lot of time...
Tried: browsed_file comment 'checked 21' and browsed_file set comment 'checked 21'
both do not work.
both do not work.
geposted Fri 14 May 21 @ 11:35 am
browsed_file isn't a verb, look up browsed_song
geposted Fri 14 May 21 @ 11:38 am
Thanks LOCODOC. (It's often the little things that make you happy....)
geposted Fri 14 May 21 @ 11:42 am
Better to use the User 1 field, "Kommentar" is already used by some Tags.
browsed_song User 1 'checked 21'isn´t working. (again one of my little syntax problems)
geposted Fri 14 May 21 @ 12:24 pm
wrap the user 1 in quote marks
geposted Fri 14 May 21 @ 12:35 pm
Note : "User 1" alias Field1 that does not need quotes
geposted Fri 14 May 21 @ 2:54 pm
With quote marks it works fine. Thanks
geposted Fri 14 May 21 @ 3:28 pm
