I just can't find it, I used to play around in VDJ 2008 and it was plain and simple.
Now all I've found is the BEATGRID pattern buttons only in the Starter Layout.
Thanks in advanced
Thanks in advanced
geposted Fri 14 May 21 @ 9:13 pm
In the pro skin you can find it as audio fx.
And if you click the cog next to the effect when you hover over, you can also see and edit patterns etc
geposted Fri 14 May 21 @ 9:19 pm
Brilliant, thanks a lot mate.
Found it
Found it
geposted Fri 14 May 21 @ 9:24 pm
