Topic: VDJ will not save database
For some reason virtual DJ will not save my database, every time I unplug my hard drive and shut down my laptop!
I Reboot it up again, plug my hard drive the database is not saved. I always have to add to search database every single time I go to DJ.
Please help:)
MacBook 15 “
i7
16gig ram
250 ssd
External WD hardrive
geposted Mon 17 May 21 @ 3:08 am
Ok thanks Beats
Didn’t work:(
You added full drive access?
IF so, is it a Windows formatted drive, like NTFS drive where you added some 3rd party read only disc program to be able to use or something like that?
Can also check directly at the folder and database xml if you have permissions.
See here : https://virtualdj.com/wiki/Settings-not-saving.html
And just in case, make sure that "readOnly" setting is set to NO
I’ve followed all instructions above and still it does not save? :(
