Hi, i have huawei AM61 Handsfree and i want to connect them, to VirtualDJ.Can anyone help me, with the setup?
geposted Wed 19 May 21 @ 7:33 pm
Its just just headphones... although via bluetooth.
Check if its available as sound card to use on the computer (speaker)
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/master.html
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/externalmixer.html
geposted Wed 19 May 21 @ 9:33 pm
I setup VirtualDJ, as it shows here
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/microphone.html
but i can't listen my voice, to the headphones.
https://imgur.com/a/vmGNAFO
geposted Wed 19 May 21 @ 11:07 pm
ah, so you meant bluetooth microphone..
Never tried, but I guess it might work ...
Check if it has any signal coming in at Windows sound settings (as well as make sure its not in use by Windows as its default recording device)
https://www.howtogeek.com/370220/how-to-set-up-and-test-microphones-in-windows-10/
geposted Thu 20 May 21 @ 9:35 am
I am going to "Recording" tab, i press"configure" and it doesn't show me "Set Up Microphone".
It shows me this window https://imgur.com/0s7yNj5
geposted Thu 20 May 21 @ 3:05 pm
i had forget to enable mic from windows settings.But still, i can't setup it, to VirtualDJ.
geposted Thu 20 May 21 @ 6:55 pm
If its available as mic in Windows sound settings, it should also be for VirtualDJ
(and if any problems, make sure Windows is not using it as its own mic)
Alternatively if its the only recording device in Windows, and you are getting errors, you can try so turn off exclusive audio in both Windows and in VirutalDJ settings
But likely it should work without doing anything, just select it and turn on mic (see link above)
geposted Thu 20 May 21 @ 7:08 pm
I setup VirtualDJ, as says the manual https://imgur.com/tgLmHhc
but only, if i have enabled speaker+headphone, as output it works.I can here deep, my voice and music, at the headset.
geposted Thu 20 May 21 @ 11:25 pm
