How to make HotCue play only while holding the button.
When I let Pad, to stop playing
Pads = piano keys
Pads = piano keys
geposted Sat 22 May 21 @ 7:58 am
You can change the sampler playback mode .. from hold to play, stutter, loop etc
Look for the Trigger Mode here:
https://virtualdj.com/manuals/virtualdj/interface/browser/sideview/sampler.html
geposted Sat 22 May 21 @ 10:03 am
No sampler.
I need Pads as piano keys.
I need 8 CUE point
1 I load a song into player one or two
2 I set (8) Cue on the song
3 The song only plays as long as I hold the Pads key
So I could play on the 8 Pads button if the song stopped when I release the button
Pads1 - 00: 01sec - (G)
Pads2 - 00: 11sec - (D)
Pads3 - 00: 24sec - (A)
Pads4 - 00: 31sec - (E)
Pads5 - 00: 07sec - (F)
I need 8 CUE point
geposted Sat 22 May 21 @ 3:35 pm
goto_cue X & play while_pressed
or something like that, depends on your note track as to how well it works.
geposted Sat 22 May 21 @ 4:00 pm
since you said piano I assumed you meant sampler, using piano keys (sounds)
For hot cues, simply change hotcueMode to stutter in settings.
And if you dont want quantize, click the small dot right above the hot cue pads, and turn off smart cue.
I guess thats what you meant for hot cues, since thats how some other DJ software acts as default
geposted Sat 22 May 21 @ 4:53 pm
I need 8 CUE points per song.
Not HOTCUE but CUE
Each PADS key is different CUE
Press PADS the song is playing, move your finger, the song stops
8 Cue points with different times, you can create music on the controller
Not HOTCUE but CUE
geposted Sun 23 May 21 @ 5:56 am
What you describe is some kind of scratchbank with modified call (I already did)
here is pad for cue1 for other cue being usable up to 32 but scratch editor is limited to 8
up ? scratchbank_unload : goto_cue 2 & play ? scratchbank_load_to_deck 2 : scratchbank_load_to_deck 2 & holding ? play_stutter : play_stutter
simple pad not using scratchbank for cue #1 and current track
up ? stop : goto_cue 1 & play
change cue n# for with every pad to pad #
if you are crazy enough ... you can try polyphonic version ^^
deck 11 clone_from_deck 0 & up ? stop : goto_cue 1 & play
change cue n# with every pad and leading deck 10+pad#
geposted Sun 23 May 21 @ 7:01 am
Not HOTCUE but CUE
Not HOTCUE but CUE
Have you tried what was suggested above ?
If you set 8 hotcues (yes hotcues is the name in VirtualDJ) and set the hotcuemode setting to STUTTER then you will get your desired behavior.
Pressing the pad will jump on the hotcue and play from there as long as the pad is held.
Removing your finger, the track will stop
Of course when you press the pads the track needs to be stopped in the first place for stutter mode to work.
Otherwise (if the track was already playing) the track will just jump on the new position and keep playing
geposted Sun 23 May 21 @ 9:45 am
