I've always had this issue. When the beat starts to wander and the markers START to not line up. When the beat markers are too fast, if I drag the "black column" - that drags all the columns up to that point as well, not just the last "Black Column". If I set a beat marker I lose a column (first gray column) after that marker. Making the next heavy marker (downbeat) on 4 instead of the next 1. If the heavy marker is too late (slow), I have no problem because setting a beat marker will move it back and lock the marker on 1, with the next heavy marker also on 1. Does anyone know how to handle this issue?
geposted Sun 23 May 21 @ 4:29 pm
When you drop the new marker, check the "1 of 4" box to mark the primary beat
geposted Tue 25 May 21 @ 6:35 pm
