Hi guys since vd launched the live stems my laptop won't run them so need to upgrade whats the lower end laptop I can be looking at buying as I no vd needs a min requirement graphics card for live stems to work thanks.
geposted Tue 25 May 21 @ 7:04 pm
Windows? Nvidia with Cuda compute capability 5 support or better (on Mac, AMD card)
See here for cards that have that:
https://en.wikipedia.org/wiki/CUDA#GPUs_supported
If you buy a modern newish laptop the CPU (regular processor) will do the job also, although slower than a graphic card. If the CPU is 7th, to 10th generation it should be a few seconds only.
A dedicated (supported) graphic card is the best solution though ;-)
geposted Tue 25 May 21 @ 7:07 pm
Rune thanks for a quick reply and thank you for some spot on info 👍
geposted Tue 25 May 21 @ 7:24 pm
