Hi, been djing with vdj for years never had 1 issue until now gear/hard drive hasn't been plugged loads since lockdown.
Was always using 4742 2018 not sure if ssd Samsung acting up as noticed folder refresh quite alot but not ejecting.
Happened again after change usb lead so cant be both usb leads.
Just 3/4/5 songs in just stops like someone clicked cue not good if went toilet etc.
Any help or idea be great really haven't changed anything windows 7.
Unless theres firmware issue with mc4000 which is only thing i have added and using.
Am using ssd/i7 so should be fine as truly only happened since testing/using mc4000 will try old set up next week.
Just updated to 2020 today testing as we speak
Latency is on 192?
Any help or pointers? Could the vdj file xml cause an issue not sure how they works as all my stuff on external ssd
Latency is on 192?
geposted Sat 29 May 21 @ 10:24 pm
