I’m using a condenser mic with phantom power into the back of my DDJ SR2. The mic is going through the hardware and not the software. I’m having to turn the volume up and down each time as there is no button on the controller to mute. Is there a way of mapping a button to mute or will that only mute mics through the software?
geposted Fri 04 Jun 21 @ 9:40 am
if its a hardware only mic and hardware controlled only mic, it cant be mapped to software
geposted Fri 04 Jun 21 @ 10:37 am
