Hi,
I'm trying map MASTER_VOLUME and HP_VOLUME to eq_high for each deck.
The master volume it's map OK,
deck left eq_high
but in HP_VOLUME when i move the knob,, appart to change de MID also change the headphone_volume:
This is my mappiing:
deck left eq_high
How i can change only MID when i move the knob??
Thanks in advance.
deck left eq_high
deck left eq_high
Thanks in advance.
geposted Sun 06 Jun 21 @ 8:29 pm
not really clear maybe you want to see
master_volume
headphone_volume
headphone_mix
eq_high
eq_mid
eq_low
https://virtualdj.com/wiki/VDJscript_verbs_v8.html
master_volume
headphone_volume
headphone_mix
eq_high
eq_mid
eq_low
geposted Sun 06 Jun 21 @ 8:45 pm
i try to be more clear:
If i want map a controller button called HP_VOLUME (headphone volume) to a EQ_HI or any EQ, the equialization works but also increase /decrease the headphone volume despite i don't any call to headphone:_volume in script
The script is veri simple:
MAP for HP_VOUME --> deck rigth eq_high
i need hat this mapping only work for increase / decrease the EQ, not both (EQ and HeadPhoen_Volume)
Thanks in advance.
Thanks in advance.
geposted Sun 06 Jun 21 @ 10:38 pm
Which controller is that ?
This means that your controller offers a hardware Headphones Volume control, so in this case you cant re-map it unless you use a different sound card.
Luilly wrote :
... but also increase /decrease the headphone volume
geposted Sun 06 Jun 21 @ 10:59 pm
I'm sorry to hear that. It's a Hercules Starlight controller
geposted Sun 06 Jun 21 @ 11:14 pm
Out of luck I'm afraid
see 12 & 13
https://virtualdj.com/manuals/hardware/hercules/starlight/controls.html
see 12 & 13
geposted Sun 06 Jun 21 @ 11:31 pm
see 12 & 13
see 12 & 13
Doubt cleared, thanks guys!
geposted Mon 07 Jun 21 @ 4:49 am
