Hi, is it possible to install MIX Station SV 04 for Virtual DJ 4.2 1024x 768 Titanium skin in the latest VDJ? I found it in the historic skins, but can't install it. Cheers
geposted Mon 07 Jun 21 @ 10:40 pm
Those are likely 10-20 years old.
Better to install from inside the software, under Extensions, for skins fully working with modern VirtualDJ
https://virtualdj.com/wiki/how%20to%20install%20plugins%20and%20addons.html
geposted Mon 07 Jun 21 @ 11:30 pm
Yes it's possible and as Rune says.... 10-20 Years old
if not installable... unzip the installer and copy the skin zip in VirtualJ\skins folder
There were known VDJ issues exposed by this skin they are ALREADY present ^^
A fix in the skin.... for XP in some cases .... not working with VDJ anymore
(most of today skins use workarounds or have artifacts just because of that)
These resizing bugs were never fixed, and some were added so that not all versions of this skin a diplay correctly and ... s said in the historic readme :
Don't close Virtual DJ with a double-screen skin !!!
2048x768 (double 1024x768) with wrong autoresize to fit one display only
geposted Tue 08 Jun 21 @ 12:19 am
