How do the new version work ? or it is broken once again?
constant 10.0 & param_1_x & param_cast & debug
param_1_x 10.0 & param_cast & debug
constant 10.0 & param_cast & param_1_x & param_cast & debug
get_constant 10.0 & param_cast & param_pow -1 & param_cast & debug
get_constant 10 & param_cast & param_pow -1 & param_cast & debug
This one need two calls
constant 0.7 & param_delta & param_cast & debug
geposted Wed 09 Jun 21 @ 1:50 pm
          param_1_x assumes it will be cast
constant 10.0 & param_1_x & debug
So does param_pow
get_constant 10.0 & param_pow -1 & debug
not sure with delta, I've not yet found a reason to use it.
So does param_pow
geposted Wed 09 Jun 21 @ 2:04 pm
          param_delta is indeed made to calculate the delta between 2 calls.
Don't remember where it is used, but probably was required for some controller at some point. (although doesn't seem to be used anymore in any of the default mappings)
param_pow can now indeed accept 2 parameters (and they can be scripts too)
param_1_x is still the same as before so applies to the slider it was called from
geposted Wed 09 Jun 21 @ 2:10 pm
          can be used for some sliders to simulate fromcenter with standard effect slider to control vst
assumes it will be cast (but does not help in any way)
-2147483648 (MININT32) as a result of 10^-1 get_constant 10 & param_pow -1 & param_cast & debug
-1 as a result of get_constant 10 & param_cast & param_pow -1.0 & param_cast & debug
10 as a result to get_constant 10 & param_cast float & param_pow -1.0 & param_cast & debug
and get_constant 10.0 & param_pow -1.0 & param_cast & param_cast & debug
as well as to constant 10.0 & param_cast & param_1_x & param_cast & debug
need more explaination on how to get the correct value of 0.1
geposted Wed 09 Jun 21 @ 2:35 pm
          thinking about it, if param_delta accepted 2 actions, we'd have param_minus
    geposted Wed 09 Jun 21 @ 2:37 pm
          @nico, don't cast before debug
    geposted Wed 09 Jun 21 @ 2:39 pm
          param_pow -1.0 `get_constant 10` & param_cast & debug
    geposted Wed 09 Jun 21 @ 2:43 pm
Yes, the backquotes ^^ and cast, thus can't be used in formats and hardly in text and to set a variable
and for other 1/x ? need pow -1.0 with backquote too
@locodog debug without cast is NoParam or boolean depending on verbs ^^ rarely other (autocast)
but here it is working, and in the opposite casting fails ^^ complex
param_1_x `get_constant 10` & param_cast & debug
param_1_x `get_constant 10.0` & param_cast & debug
param_1_x `get_constant 10` & debug
are NoParam
get_constant 10 ¶m_1_x & debug
param_add 5.0 5 & param_1_x & debug
are OK
difficult to figure out and to follow everything
geposted Wed 09 Jun 21 @ 3:05 pm
