Hi, I am finding that when i plug my midi controller in to my computer, the software switches off. The software runs fine without it plugged in. It shuts off within about 2 seconds of plugging the controller in and before it shuts down it flashes the new equaliser settings window for a fraction of a second. long time user of vdj 2021 pro version. Never had this before and help would be appreciated.
geposted Sun 13 Jun 21 @ 4:38 am
I don't know how to help, and I am sure that more info would aid those who can.
For example: Any controller? every controller, which controllers?
which build of VDJ are you using? (Maybe even OS and version)
has there been a change with a controller or software update or mapping etc ?
have you tested with all defaults.. default VDJ and all default Mappings?
geposted Sun 13 Jun 21 @ 6:48 am
Im using vdj2021 with latest updates. I run a ave 4 channel midi controller connected to a hp pavillion i7 7th gen laptop. the software shuts down as soon as i connect the controller. With controller disconnected, software runs fine. soon as i plug in the usb cable to midi controller, the software shuts down.
geposted Sun 13 Jun 21 @ 8:15 am
i cant fix this porpmable
geposted Sun 13 Jun 21 @ 7:37 pm
