I'm having one of those years. Today's brain fog is killing me . I'm trying to take a dial slider and make it work for each for stem . Vocal on off worked on the button but I want the dial to fad it in and out . I had eq but I wanted my regular eq to stay as it is I use both at the same time . Eq and stem. I usually know this but my brain is toast lately ..thanks in advance
geposted Wed 16 Jun 21 @ 10:54 pm
stem kick, stem bass, stem vocal, stem instru, stem hihat, stem rhythm, stem melody, stem melovocal
all 8 are working with sliders (they are from center, same as a color slider)
0.0..0.5 = level muted to normal
0.5..1.0 = level normal to solo
note stems are in interaction with other, soloing vocal will mute instru and rhythm
keep frequencies as default for eq
if you want to add slider... only skin modification can do (DO NOT USE CUSTOM SLIDER they are too broken)
if you want to map a controller no problem
geposted Wed 16 Jun 21 @ 11:12 pm
thanks got it..
geposted Thu 17 Jun 21 @ 3:11 am
