When I used to open up virtual dj, a controller configuration screen would pop up and allow me to use the controller 3 different ways. It stopped doing that and now i can no longer use my controller correctly. Any idea how to get this screen to come up again?
geposted Tue 29 Jun 21 @ 4:59 am
eq popup?
need more info what the pop up was.
geposted Tue 29 Jun 21 @ 6:04 am
Open Settings -> Options and search for "dontShowAgain" option.
you can either click on "X" icon on the left of the setting to delete all it's contents and therefore get notification for everything again, or delete only the part you need.
The values stored on that setting are comma ( , ) separated, so make sure you delete it properly.
Most likely you'll want to delete something like "DDJ800-detected,"
As I said, make sure you delete the comma as well and you leave only one blank space between values.
geposted Tue 29 Jun 21 @ 9:03 am
Wedding Jamz DJ wrote :
....allow me to use the controller 3 different ways. ..
Hmm i wonder what were the 3!! ways.
The "Hardware Detected" window that pops up by default when a Midi controller is connected, has 2 buttons to choose the Audio setup (computer sound card or controller), but thats 2 "ways"
Unless you refer to the Equalizer/Stems mode window.
geposted Tue 29 Jun 21 @ 1:41 pm
