-get_automix_song can access order and position columns
-"mix_next +4" can mix to the 4th upcoming song in automix
how do you apply that?
geposted Fri 02 Jul 21 @ 10:26 am
Just an idea..
PS:
'get_automix_song' action could access all columns but the new ones like order. So now it can access all columns again.
Finally "mix_next" was able to mix only the NEXT track from the automix list.
Now it can use parameters to jump further down and mix the second, third, or forth track in the upcoming automix list (like pressing the mix button twice/triple times e.t.c.)
geposted Fri 02 Jul 21 @ 10:42 am
I would like a video skin that played the music video in say 60% of it at the top corner, then the automix list at the side and the titles, spectrum etc. below.
Would that be possible?
Doesn't seem there's been any development on video skins for a while now.
geposted Fri 02 Jul 21 @ 11:00 am
PhantomDeejay wrote :
Just an idea..
PS:
Just an idea..
PS:
@PHANTOMDEEJAY
I don't know what kind of surface it is
geposted Fri 02 Jul 21 @ 11:18 am
Of course it's possible, and actually it's quite easy to code it.
I don't think it would take more than maybe 100 lines to make such a video skin
geposted Fri 02 Jul 21 @ 11:20 am
Benz Werner wrote :
@PHANTOMDEEJAY
@PHANTOMDEEJAY
It's not a surface.
It's just a skin.
Actually it's a VIEW (layout) of one of my skins I'm currently working on.
It's a "Jukebox" layout BTW. Just as a demonstration of what the actions you asked for can be used at.
geposted Fri 02 Jul 21 @ 11:23 am
@PhantomDeejay
You provide this skin for download when it is finished?
I'm excited about it!!
geposted Fri 02 Jul 21 @ 11:43 am
Yes, it will be an update of my GTS-2K21 skin.
geposted Fri 02 Jul 21 @ 12:44 pm
Also check the 2 deck scratch you recently added. It go BLANK, it doesn't show the Scratch wave when switch from any of the other 4 choices already on it.!!!
geposted Fri 02 Jul 21 @ 7:53 pm
Hello Phantomdeejay,
how far are you with this skin?
geposted Sat 17 Jul 21 @ 7:00 am
