There is a small bug using the FX channel switcher on the DDJ 400. It will work fine sometimes and then other times the channel doesn't match what is on the controller. For example if could be switched to channel 2 on the controller but the FX affects channel 1. I would have to switch it again for it to match up back with the software.
I am using the latest version of VDJ (6541) and the latest firmware for DDJ 400 (1.03)
My PC specs:
OS Name: Microsoft Windows 10 Pro
Version: 10.0.19041 Build 19041
OS Manufacturer: Microsoft Corporation
System Manufacturer: HP
System Model: HP ProBook 440 G6
System Type: x64-based PC
Processor: Intel(R) Core(TM) i5-8265U CPU @ 1.60GHz, 1800 Mhz, 4 Core(s), 8 Logical Processor(s)
Installed Physical Memory (RAM): 8.00 GB
Total Physical Memory: 7.87 GB
My PC specs:
geposted Sat 03 Jul 21 @ 8:40 pm
If you are using a Custom mapping (much different from Default) and still want to use that along with the fix, open your Custom mapping xml file with a Text Editor and replace all DDJ400_FXASSIGN with $DDJ400_FXASSIGN
geposted Sun 04 Jul 21 @ 7:37 pm
Thanks much DJDad! Will do the testing today and report with the results
geposted Tue 06 Jul 21 @ 2:33 pm
This worked perfectly. Thanks.
geposted Tue 06 Jul 21 @ 5:06 pm
