I have a bunch of vdj 7 script with holding that does not work in vdj2021, I just try this, "holding 1000ms ? play deck 1 : play deck 2", and it did not work, only deck 1 play, is holding broken, or what is equivalent in vdj 2021 ?
geposted Wed 07 Jul 21 @ 4:05 pm
works fine here
geposted Wed 07 Jul 21 @ 4:11 pm
holding works, your v7 syntax doesn't
holding 1000ms ? deck 1 play : deck 2 play
specify deck, then action.
geposted Wed 07 Jul 21 @ 4:12 pm
Example above play deck 2 but not deck 1
geposted Wed 07 Jul 21 @ 4:44 pm
not here, hold for a second deck 1 plays, single quick press deck 2 plays
geposted Wed 07 Jul 21 @ 5:23 pm
you can test holding lke this:
holding 1000ms ? debug long : debug short
@locodog
inverting the test does not seems to work correctly
holding 1000ms !? debug short : debug long
first short press not reported, long press reports short then long releasing button
@locodog
geposted Wed 07 Jul 21 @ 5:29 pm
@nico doubleclick also acts wrong with inverted query but, it's not really a surprise.
geposted Wed 07 Jul 21 @ 5:43 pm
