after a few songs the sounds goes to popping and like crazy noise over the music ; Help please someone?
geposted Thu 08 Jul 21 @ 7:33 pm
Is there an ASIO control panel installed with the drivers?
If so increase the latency.
geposted Thu 08 Jul 21 @ 7:51 pm
Try set buffer (latency) to 256 or 512 in the Rane asio driver.
(if not using Asio, do same inside VirtualDJ, under latency)
Can also try this tool to identify things preventing real-time audio:
https://www.resplendence.com/latencymon
geposted Fri 09 Jul 21 @ 12:18 pm
Yes there’s a ASIO set up but still does it
geposted Mon 16 Aug 21 @ 10:17 pm
