Hi folks,
I was wondering if playlists are handled as a query, so they can update if a new item is added inside the playlist criteria eg 2020-2021 Hits? Or is it an absolute Db static list?
Secondly, if I trigger a playlists from Event Scheduler on a remote machine, is there any way to force the 'shuffle' option?
Thank you
M
Thank you
M
geposted Mon 12 Jul 21 @ 10:13 am
the script is "playlist_randomize" I don't get the first thing you're asking.
geposted Mon 12 Jul 21 @ 10:17 am
The question is not really clear
Playlists (as well as virtual folders) are static lists of links to track files
Not related to DB
If adding a filter folder with criteria to a playlist this will only add files present at the time the add is done
Anyway, adding it again only updates the new added files (no duplicated)
but this is a manual operation (can be scripted though using playlist_add)
Not related to DB
geposted Mon 12 Jul 21 @ 10:56 am
thank you very much
geposted Mon 12 Jul 21 @ 1:28 pm
