Hi, i´m getting randomly misfunction on the controller. one side of a Deck is playing fine, i load the other Deck, when i move now the Jog on the new loaded track,everything works fine, the track is moving along the turning of the Jog. But some time later it automatically jumps into "fast search mode" without the SHIFT Button being held. Sometimes the normal function can be established, when the SHIFT Button is pushed and jused with the Jog as intendet to fast search - sometimes not. Than loading an other Track on given Deck "repairs" the Problem. But here too, sometimes the Problem won´t go away. I can´t reproduce the Problem at will.
What could cause the Problem?
https://www.virtualdj.com/manuals/hardware/denon/mcx8000/layout/decks.html
geposted Wed 14 Jul 21 @ 8:26 pm
Most of the times this happens if you release SHIFT before releasing the jog. So using SHIFT+ JOG again but this time releasing with correct order, you should get the normal behavior back.
It's something that we need to improve though, because the hardware functionality doesnt help in most cases.
geposted Thu 15 Jul 21 @ 4:57 am
