Hello
As some of you have probably worked out i love customizing this software to help me with my DJing needs. However i recently have tried to manual beatmatching but i was wondering if anybody knows what to remove in the XML editor to hide(remove) the deck BPM readouts (in the redbox )so all i have is the waveform and the beat bar as my visual aid
if anyone can help me that will be great
geposted Fri 30 Jul 21 @ 5:25 pm
Depends on what skin and what variant of it.
Easier just to put some black insulating tape over the screen.
geposted Fri 30 Jul 21 @ 5:44 pm
@kradcliffe love the lofi fix but tape leaves sticky marks, "close your eyes" isn't progress.
@DISCO SPINNERZ
ctrl+h
find
%Pbpmex
replace all with
[above means replace with blank, nothing]
again, find
%bpmex
replace all with
save
reload the skin
@DISCO SPINNERZ
ctrl+h
find
%Pbpmex
replace all with
again, find
%bpmex
replace all with
save
reload the skin
geposted Fri 30 Jul 21 @ 6:35 pm
okay thanks i'll try thar
geposted Fri 30 Jul 21 @ 7:04 pm
