When a new song is loaded to deck in this version, a message "Loading Deck #" appears then it is followed by another message "Computing Stems Deck #". Depending on the size of the song loaded, this action last for up to 14 seconds. During this period the system spikes to 70% and performance is degraded. I use VDJ during a Music/Video stream, during this degrading period, the streaming software stops functioning. During my last as a test, only vinyl records were played, thus I did not used VDJ at all and did not experience the problem. Am I incorrect in making the determination that this action is causing the a problem? Please let me know if there's anyone else experiencing this problem. Thank you Cheese
geposted Fri 30 Jul 21 @ 9:07 pm
I do not use a mac but you can disable the stems
geposted Fri 30 Jul 21 @ 9:20 pm
This suggests that either your computer is underpowered for use with stems, or you're loading a very long track.
It is intentional to see up to 100% during analysis.
If you're streaming to one of the common platforms, you can stream directly from VDJ. It is not necessary to use other software.
geposted Sat 31 Jul 21 @ 9:27 am
