Does anyone use VDJ with a Pioneer DDJ1000SRT or another board and use DVS with it? If you do, do you experience the pitch auto adjusting to a much slower BPM ramdomly as soon as the needle hits the vinyl? Mine does. 99% of the time I have to manually reset the pitch back to 0 then start to match. And yes, every auto sync and auto etc. is turned off. Is this just some software glitch with VDJ and using DVS maybe? This is cery aggravating. Thanks for any help.
geposted Sun 01 Aug 21 @ 9:24 pm
