in vdj8 using the q2 deck option, after putting a song on deck a which works ok. then when i put a diffrent song on deck b instead of the new song appearing on deck b, the same song that is on deck a appears on deck b instead of the new song. any ideas why? thanks in advance for any help you can give
geposted Tue 03 Aug 21 @ 10:08 pm
I have seen this before, I've never got to the bottom of it, it's like only one deck is created, [2 decks are drawn but both are deck 1] I've had it with my pretty rough work in progress skins, but I've also seen it in some cases with default skin [but those I reported]
geposted Wed 04 Aug 21 @ 9:52 pm
