I buy a party music numark and first I downloaded it serato dj lite I think I made an error and I do not have the password number to be able to put it in the serato but when installing the serato I put computer and I did not put the party music .I decided to download the virtual dj but in the configuration I have serato nose if they can help me please
geposted Thu 05 Aug 21 @ 1:40 pm
Make sure you have selected the correct audio settings for the party mix and connect your speakers to the back of the unit as it has built in sound card and if you have no licence it should work up to 30 day's trial but that has ended you must purchase a licence if you just using it at home a home only licence is $49 but others are available hope the info helps.
geposted Thu 05 Aug 21 @ 4:50 pm
