Hi,
Is Virtual DJ working on the Merge Fx for the FLX6 .
Great work on de mapping. Evertthing works good on the new controller.
Thx.
Studio Hagenbroek.
Thx.
Studio Hagenbroek.
geposted Fri 06 Aug 21 @ 9:46 am
The merge fx on the FLX6 is not mapped in VDJ. I think is still listed as "coming" in the VDJ hardware manual for it
But until there is no need to leave it "empty" if you like it to do something with stacked effects
Based on a question on FB regarding this, I did an example for what you could chose to do
The scripts are in the video description if you want to see them
geposted Fri 06 Aug 21 @ 11:30 am
Thx
geposted Fri 06 Aug 21 @ 4:10 pm
Your script works fine.
Tomorrow video's.
Tomorrow video's.
geposted Sun 08 Aug 21 @ 1:55 pm
Dear Support,
How can I map MergeFx_Sel on Virtual dj for FLX-6? Please provide an example.
geposted Sat 04 Dec 21 @ 6:30 pm
cmagalha wrote :
Dear Support,
It depends on what you want it to do
If you want it to change something else - like which fx are triggered when you push the merge fx button, then maybe just set a variable, that you can the query when you create your merge fx script
If you set it to go through assigning values 1, 2, 3 and 4 in the variable, then you can also map the LED_MERGEFX_SEL1, LED_MERGEFX_SEL2, LED_MERGEFX_SEL3 and LED_MERGEFX_SEL4 LEDS to lite up at the correct value of the variable
geposted Mon 06 Dec 21 @ 12:15 pm
Hello everyone,
I have a FLX6-GT controller since today. Is there any way to change the preset Marge Fx effects?
geposted Wed 10 Apr 24 @ 7:41 am
No.
geposted Wed 10 Apr 24 @ 9:02 am
