Hey, does anybody know if my beloved Numark V7 will run with VDJ on a Mac M1 Big Sur? Thanks in advance.
geposted Tue 10 Aug 21 @ 10:00 am
You'd probably need to check if the Numark drivers were compatible as the V7 isn't class compliant. Being part of In-Music I would doubt it as they never update anything.
VDJ certainly is.
Edit, as suspected there's no support as yet. Wouldn't hold your breath!
VDJ certainly is.
![](/img/341448/58492/image_2021-08-10_110806.png)
geposted Tue 10 Aug 21 @ 10:05 am
thanks for your quick reply. and yes, of course Numark ditched support for older gear. So if they provide no updated drivers there is simply no chance to bring them back, correct?
geposted Tue 10 Aug 21 @ 10:34 am
Looks like it. Unfortunately older controllers that aren't class compliant do get left behind.
That's why I prefer Windows as there's always generally a solution out there.
geposted Tue 10 Aug 21 @ 10:37 am
