i have a ddj800 i can it turn off shop demo mode i check the off button and close the menue and it swiches back to on need help
geposted Wed 11 Aug 21 @ 8:50 pm
To avoid actually deleting settings you can open the xml in notepad and search for
<shopDemoMode>yes</shopDemoMode>
change to no and save.
geposted Wed 11 Aug 21 @ 10:17 pm[ selected best answer by locoDog on Wed 11 Aug 21 @ 10:20 pm ]
the only way : delete settings.xml
geposted Wed 11 Aug 21 @ 9:02 pm
Go into options in the search box type demo and it will come with an option of turning the shop demo off I have just looked for you.
geposted Wed 11 Aug 21 @ 9:13 pm
Just to add there is no need to delete settings.xml
geposted Wed 11 Aug 21 @ 9:15 pm
was previously readonly when in demo mode (security in a way to prevent guest to do such an action)
geposted Wed 11 Aug 21 @ 9:20 pm
He should of said that in the first place What he needs to do is go into settings in windows or mac and check the security settings to make sure everything to do with vdj is not locked out.
geposted Wed 11 Aug 21 @ 9:33 pm
Quickest way is to delete settings.xml
Selected as best answer geposted Wed 11 Aug 21 @ 10:17 pm
