Hi, I would like a custom button to swap between shader and slideshow. Tried a few things but can't nail it.
Thanks!
Thanks!
geposted Tue 17 Aug 21 @ 10:11 am
[presuming deck master] Which slot, video fx or audioOnlyVis?
geposted Tue 17 Aug 21 @ 10:24 am
Master. Source for audio only tracks
Shader: auroraborealis and slideshow where I have a static image.
geposted Tue 17 Aug 21 @ 10:29 am
audioOnlyVis slot
effect_select 'audioOnlyVisualisation' 'shader' ? effect_select 'audioOnlyVisualisation' 'slideshow' : effect_select 'audioOnlyVisualisation' 'shader'
video fx slot
deck master effect_active 'shader' ? effect_active 'shader' & effect_active 'slideshow' : effect_active 'shader' & effect_active 'slideshow' off
video fx slot
geposted Tue 17 Aug 21 @ 10:36 am
First one did the trick. Thank you!
geposted Tue 17 Aug 21 @ 10:46 am
