Strange, but after latest update, when loading song , vdj start crushing. Im using win10
Anyone else has this problem
geposted Thu 19 Aug 21 @ 11:51 pm
what version, seems a bug on latest release
geposted Fri 20 Aug 21 @ 12:02 am
Some how my mapping of my Keyboard got change....after update
geposted Fri 20 Aug 21 @ 12:16 pm
HELP!!! Just added the latest update and now as soon as I open and load a song, it totally crashes. Got gigs tomorrow, please help!!!
geposted Fri 20 Aug 21 @ 1:23 pm
@TJR504, go for 6541
https://virtualdj.com/download/build.html
geposted Fri 20 Aug 21 @ 1:38 pm
I have the same issue. Immediately after loading a song, it crashes. Been trying to set up a new playlist, each times this disappears with none of the newer imported songs and the playlist disappears from the quick view on right hand side (keeps being replaced by previous playlist that was sitting there)
geposted Fri 20 Aug 21 @ 1:56 pm
FIXED! THANKS A LOT!!
geposted Fri 20 Aug 21 @ 2:09 pm
I have the same issue. Immediately after loading a song, VDJ it close, have to download the webside version and installed v 6541
geposted Fri 20 Aug 21 @ 2:13 pm
Downloading the previous version, as suggested, worked, thank you.
geposted Fri 20 Aug 21 @ 2:26 pm
Hello guys,
My cue volume is super low after the last update
geposted Fri 20 Aug 21 @ 3:34 pm
VDJ immediately issue new update ver. 6609 with the fix. Works fine now. Had something to do with CPU math.
ps. Never update at the day or day before of the gig
geposted Sat 21 Aug 21 @ 1:39 pm
I went back to version 6541, all is well. Thanks....
geposted Sat 21 Aug 21 @ 2:00 pm
My mixer is not working with virtual dj. Please help
geposted Sat 21 Aug 21 @ 2:52 pm
vdj supports most of the controllers available on the market. You have to get vdj licence to use them
geposted Sat 21 Aug 21 @ 8:07 pm
If it's the MD/W 1311 controller i see in your Account stats, then try to install this driver https://virtualdj.com/documents/Drivers/JBSystems_UsbAudio_v4.82.0_setup.exe
If still not working properly, please open a new topic with a relative title.
geposted Sun 22 Aug 21 @ 4:03 pm
No puedo realizar la ultima actualizacion
geposted Sun 22 Aug 21 @ 7:50 pm
