Forum: Wishes and new features
Topic: "Own STEMS from DAW" Support
I think, that VirtualDJ should enable to import own stems from DAW (Kick,Hihat,Bass,Instrument,Vocal) for music Producers...
If I own source stems of the track, why should I degrade the quality with realtime stems?! If I don't own source stems of the track, then I can use realtime stems, because realtime stems are better than nothing ...
I have found a workaround, how to create .vdjstems from my DAW, but it does not work 100% right.
geposted Sat 21 Aug 21 @ 7:08 am
Hi,
I found the way, how I can make own STEMS. All works fine, but I have found a 'Bug' by my own Stems.
If only Vocal and Intru play together, then I hear a little bit of Drums too. If I play Instru only or Vocal only is all OK. Blend is of course 0! I have tested my files in VLC, my DAW etc. and there all is OK.
Can VDJ team enable to use own STEMS without this 'BUG'. Thank you very much.
