Each time I set my hot cues for my playlist in the side list tab and autoplay list once I close the app and relaunch it all my hot cues have been deleted, this didn't use to happen - Is there a setting I need to save them ?
Also if I save a playlist when I load it back up again it loads up in alphabetical order rather than the order I had arranged it in - Is there a cure for this ?
Thanks James
Thanks James
geposted Sat 21 Aug 21 @ 1:49 pm
Might be lack of write permission for the software, either to Documents folder or the external drive.
Easiest fix is just give VirtualDJ full disc access
https://virtualdj.com/wiki/Settings-not-saving.html
geposted Sat 21 Aug 21 @ 3:58 pm
Hot cue saves has been fixed thanks ! That's going to save me a lot of time !
Playlists are still be reloaded in alphabetical order though which is really annoying, is there a cure for this ?
geposted Sun 22 Aug 21 @ 10:21 am
in the folder tree or the songs themselves as content of a playlist?
For folder : Drag and drop to rearrange (and this is saved to a file to store order for next time)
For songs : Right-click any column header in the browser when playlist is open, and choose "reset sort order" ... and/or right-click any column header and opt to show the "order" column for easy toggle between different sorts
geposted Sun 22 Aug 21 @ 12:45 pm
