My question is like
After released from the keyboard then the action work. Something like;
deck 1 play : deck 2 stop immediately after release, if still the key is pressed then deck 2 still until I release my finger.
Thanks
Thanks
geposted Mon 23 Aug 21 @ 12:26 pm
Please Bossmen still waiting
geposted Mon 23 Aug 21 @ 7:07 pm
I think everyone is also waiting for you to buy a license ......
geposted Mon 23 Aug 21 @ 7:31 pm
Not intension, don't have, now working small small to get money to buy, not having controller so I want my keyboard be perfect and easy that why asking. Play if get I will buy
geposted Mon 23 Aug 21 @ 11:03 pm
read how the
down
action works
down
action works
geposted Tue 24 Aug 21 @ 3:02 am
Thanks Boss.
What I have done is
''down ? deck 1 play & deck 2 level -0.003125 : deck 2 stop'' I want to do another action so that when this is working I can use the 'loop', 'loop_half' and 'loop_double' on the deck 2 but when I started pressing on, the 1 action pauses.
I want how I can lock it so that the 1st action will be pressed once and do the action.
Thanks
What I have done is
Thanks
geposted Tue 24 Aug 21 @ 4:35 am
What should I add to the level to continue until it get to 0% so that I can work on the loop
geposted Wed 25 Aug 21 @ 9:52 am
try things like that :
deck 1 play & repeat_start rvl 170ms 22 & deck 2 level 0% ? repeat_stop rvl & stop : level -5%
geposted Wed 25 Aug 21 @ 12:03 pm
Bro, Thanks much. God bless you. Wow
geposted Wed 25 Aug 21 @ 1:29 pm
