New version of undo_load accept parameter "any"
this unloads and reloads the last deck which was loaded whatever the action deck can be
now the bug :
using the same action again will this time apply to action deck
which is not the last loaded, because the last loaded deck didn't change to action deck, it only unloaded and reloaded the same deck that is still the last loaded one
"undo_load any" seems not to unload the last loaded deck but better unload the last action deck the load was initiated from ^^
This is not a good idea, better undo_load a deck and re undo_load the same in a way to restore original state
Other issue :
Translation of description changed in english version what is normal
however in other languages (at least french) it disappeared instead
now the bug :
Other issue :
geposted Tue 31 Aug 21 @ 6:15 am
"undo_load any" undos the load from the last deck a song was loaded on. (and that had a track loaded before)
Pressing it again will udo the load from the second-to-last deck a song was loaded on and so on.
I guess you expect to undo the undo when pressing it again? Switching between the 2 last loaded songs endlessly?
I'm not sure which behavior would be more useful.
geposted Wed 01 Sep 21 @ 6:28 am
Yes, exactly or better a redo after undo but yes why not a "redo_load" for that
We can't complain against a feature asked for a long time :)
geposted Wed 01 Sep 21 @ 6:38 am
