I have Virtual DJ Pro 2021 installed on my computer ("Windows10") with PRO license. I am using a "Denon Dj MC4000" controller and an "Akai APC Mini" controller. Everything works without any problem.
I bought a new HP laptop ("Windows10"). I installed the same version of Virtual DJ and connected the same controllers and it turned out that the program detects the Denon DJ controller and not the "Akai APC Mini". In Windows10 the "Akai APC Mini" controller is detected (in the Bluetooth and other devices tab).
Please help me what should I do to make Virtual DJ program detect "Akai APC Mini" controller.
geposted Wed 01 Sep 21 @ 10:06 am
did you install the akai software?
geposted Wed 01 Sep 21 @ 11:58 am
To get the akai software you will need to go to the akai web site here is the link https://www.akaipro.com/softwaredownload you may need to regester and follow the on screen instructions.
geposted Wed 01 Sep 21 @ 1:53 pm
I forgot to say vdj should see it as it plug and play.
geposted Wed 01 Sep 21 @ 1:59 pm
It's already working.
I installed the program "Ableton Live" which I received in the set with the controller "Akai". ( my opinion ) - During the installation of Ableton Live the new Windows system received some "library" files that opened the way for Virtual DJ.
Thank you for your help.
geposted Sun 05 Sep 21 @ 8:58 am
