Topic: Stem Separation Not working
Hi, i need help with my virtual DJ, i cannot separate stems, because math engine on my virtual DJ is set on automatic, every time i change it will freeze out the virtual dj. The rig i use is ROG Flow X13 AMD Ryzen 9 5900 HS, RTX 3050, 16GB. What should i do for the stem to be working?
geposted Tue 28 Sep 21 @ 4:53 am
Are you sure extra dll needed were downloaded correctly ?
https://virtualdj.com/forums/235626/VirtualDJ_Technical_Support/GPUs_that_support_new_math_feature.html
specially
PROART wrote :
Found out why the math engine did not work with my Nvidia cards.
The required DLL cud101 and cuf101 in the Plugins64 folder was not fully downloaded.
Nicotux wrote :
When download fails (or times out) VDJ just disable the feature but can't detect it was not correctly downoaded (at least with previous builds, may have changed)
In this case, manually delete the partial (or 0 length) dlls in a way VDJ download them again at next run (took me some tries with slow networks)
