I don't know what happened. I was using my SX2, all was ok. Went t0 eat dinner. Fired back up and settings changed. Its crazy. Things don't play left and right decks. Then they only play out the means when I hit Cue for headphones. Headphones play nothing at all with or w/o cue enabled. HELP!!!
What are the settings supposed to be at. I am so screwed trying to prep for this wedding. Thanks
geposted Mon 04 Oct 21 @ 10:32 pm
Don't really know what happened
maybe SX2 went in sleep mode or system USB power shut down
the config thus changed and VDJ auto reconfigure without SX2
in this case you can
- unplug and plug controller again, possibly using an other port
- restart computer
if not working :
goto audio config and force SX2 setup if present
In every case Infos about System, OS, VDJ version and a screenshot of audio config (both system and VDJ) may be useful for better help
- restart computer
if not working :
geposted Mon 04 Oct 21 @ 10:43 pm
I honestly have no clue wtf happened. But I figured it out setting by setting through trial and error. Seems to be working right. I saved back up settings for the controller to. I assume make sure its on SX2 and channels 1/2 for deck 1 and 3/4 for deck 2 and have headphones the same and alls well. I will test more tomorrow. Im tired and stressed from that.
geposted Mon 04 Oct 21 @ 11:42 pm
you may want to read this carefully sounds like your setup is incorrect
https://virtualdj.com/manuals/hardware/pioneer/ddjsx2/installation.html
geposted Tue 05 Oct 21 @ 12:00 pm
thanks to you both
geposted Tue 05 Oct 21 @ 7:37 pm
