Topic: My VCi400 seem to reset need help - Page: 1
So I gotta remap my vci400.
My problem is the 8 pads again.
My 1st rotary encoder is mapped to scroll through the pad pages.
My Mode 1-4 buttons are mapped to select 1.stems 2.slicer 3.loop 4.sampler pad pages.
The problem is the pads don't respond to those mapping. So I look at the pad mapping and the have changes somehow.
Ex. Pad1 is mapped like this
(Pad1: var '$sampler' ? Sampler 1 play_stutter & sampler 1 select : var '$shift' ? Delete_cue 1 : hot_cue 1)
Which is not the custom mapper I normally use. Can I get help?
geposted Sat 16 Oct 21 @ 2:11 am
use mapping from a backup
If I had it I would....
If you use the normal pad pages then the buttons to be used as pad can simply be mapped as 'pad 1' etc
you haven't used the backup function once in the 2 and a half years it's been available?
Man I don't know what happen. I been search for files and back ups ever since I upgraded all my hd's to SSD. I have backups that I can't find. Some are in my Google Drive nit my vci400 mappings. My voxao m70 c60 and denon 3900 are there but not vestax 400 stuff...
The way I had it the mode buttons are like quick recall. Can the "Pad 1"
Still be used...
you don't have a "backup" folder in vdj home folder?
the in built feature saves mappings.
@adion shouldn't "/Devices" also be included?
If they use pad_page or pad_page_select then yes, you should use "pad" on the pads
Didn't work. Had a show this weekend and couldn't get back on this until now....
I'm using my custom definition and reverting my pads to Pad1 - Pad8 mapping doesn't work. The encoder is map to pad_page_select, the mode buttons are pad_page 1 Hot Cues (using 4 different pages for each).
But it's not working.
I've also seen other post about mapping errors since the last EA update.
Any help....anyone...
I figured it out.
How do I get the mode 1-4 buttons to only be lighted according to mode selection. Right now they are all on.
Help please
I feel black balled....lol...blacklisted...
lol you re not blacklisted, but would help to know which are the keys you have mapped and how.
E.g. the default mapping has..
<map value="MODE1" action="pad_pages 1" />
<map value="MODE2" action="pad_pages 2" />
<map value="MODE3" action="pad_pages 3" />
<map value="MODE4" action="pad_pages 4" />
<map value="LED_MODE1" action="pad_pages 5 ? blink 750ms : pad_pages 1" />
<map value="LED_MODE2" action="pad_pages 6 ? blink 750ms : pad_pages 2" />
<map value="LED_MODE3" action="pad_pages 7 ? blink 750ms : pad_pages 3" />
<map value="LED_MODE4" action="pad_pages 8 ? blink 750ms : pad_pages 4" />
Mode 1
Pad_page 1 Stems
Mode 2
Pad_page 2 Loops
Mode 3
Pad_Page 3 slicer
Mode 4
Pad_Page 4 Sampler
LED1
pad_page "WHATEVER_PAD_ON+5" ? blink 750ms : pad_page "Stems"
It changes the pages but the Mode LEDs are always on.
80%
