Hi,
I quite often use the Ez mixing mode for my controller but for some reason, it keeps adjusting the EQ or keeps resetting after each track played. Is there a way you can lock in the eq levels so it stays the same throughout and then use the Ez mode without it keep resetting/ adjusting?
geposted Mon 18 Oct 21 @ 4:59 pm
type "reset" in options, see what it brings up.
geposted Mon 18 Oct 21 @ 5:16 pm
