Topic: Tempo + Pitch problems
I figure this issue is most likely a simple fix but heres my issue;
After the song is cued up and I start the song, many times I have to play with the pitch and put back to the middle because it's either too fast or too slow.
I don't need to match tempos since I am performing while using this but it throws off my performance. HELP! Thanks
geposted Tue 19 Oct 21 @ 4:46 pm
check settings for
autoBPMMatch
smartPlay
autoPitchLock
Thank. All 3 are set to NO. Don't know what else to check. Thanks though
there's 1 setting I always forget with pitch issues, could you post a video of the issue in action.
It's on the tip of my tongue and it's been the fix 100 times but I'm struggling
I think you have listed all of them Locodog
Smartplay can be per deck though .. so if checking deck 1 and its off.. it could still be on for deck 2 and causing the issue at times...
and Klaus has created this awesome video which may be of help
