lately i have been experiencing a distortion sound going through my speakers and headphones. the only thing I can think of is that Ive downloaded some vocal effects from the add ons page. this distortion sound comes with in the first 20 min of using Virtual Dj. so I typically close out VDJ and restart the program. and it plays just fine after sometime it comes back again. Please help me in anyway. suggestions or solutions I just don't know what to do of what It could be. Is anyone else having this issue I have been a VDJ member since 2008 and a pro member since 2010. Thank You, VDJ TEAM. I did delete the program and re downloaded VDJ but I'm still having this issue.
geposted Tue 26 Oct 21 @ 11:22 pm
Do not know what your config can be but it sounds like a problem related to audio config
(maybe some buffer error in ASIO sync with multiple audio boards on Windows)
you may try to map a button/key to "apply_audio_config" and see if it helps instead of restarting VDJ
For a better help with such problems better specify OS, CPU/GPU and post screenshot of audio config
geposted Wed 27 Oct 21 @ 12:07 am
Hey, how do you do that?
geposted Wed 27 Oct 21 @ 1:51 am
