Hello all
Just like to ask the question regarding the new Mac Update (Monterey)
Is it safe to do this update, and more importantly is VDJ2021 stable with this update
Thanks in Advance
Thanks in Advance
geposted Wed 27 Oct 21 @ 8:54 pm
No it's not officially supported yet according to the wiki.
A few users complaining of errors.
geposted Wed 27 Oct 21 @ 9:05 pm
I updated on my MacBook last night and virtual Dj launches but is invisible. I downgraded back to big sur with my time machine back up so it’s all good. It doesn’t work yet
geposted Wed 27 Oct 21 @ 9:30 pm
Where do I see the status of the current compatibility situation? I tried to check the general requirements (like supported OS) but cannot find anything?
Thanks in advance...
Best regards,
Steffen
Best regards,
Steffen
geposted Fri 17 Dec 21 @ 11:31 pm
Best regards,
Steffen
Best regards,
Steffen
The virtual dj team posted it on their Instagram page about compatibility with windows 11 and Mac OS Monterey. From my personal experience, it loads super fast on the OS and is smooth with other tasks as well. I am experiencing a few lag/ sound quality issues related to scratching etc etc but that’s probably because vdj is still getting to grips with the S11 and CDJ -3000
geposted Sat 18 Dec 21 @ 10:12 am
geposted Sat 18 Dec 21 @ 11:04 am
Thanks!!
geposted Sun 19 Dec 21 @ 12:27 am
Dans documents j'ai copié virtualdj avec les playlist etc que j'ai collé dans mon mac 2 documents .dans mon compte j'ai téléchargé virtual dj vers mon mac 2.Pas de problème d'ouverture mais le chargement des titres se fait par saccade et la souris est incontrôlable pendant ce chargement. mac 1 avec catalina pas de problème mac 2 avec BIG SUR ET MONTEREY même problème.Si quelqu'un a une solution merci
geposted Thu 21 Jul 22 @ 3:55 pm
