It's possible on DDJ 1000 replace parameter "get_pioneer_display "beatanchors"" to view harmonic key song and no the musical key song?
geposted Sat 30 Oct 21 @ 1:33 pm
get_pioneer_display "beatanchors" has nothing to do with keys and harmonical mixing.
That being said, please change the following key on your mapper:
DIGIT_KEY_VAL
And set it's action to
Then depending on how you prefer to see the key on VirtualDJ the DDJ-1000 screen will follow up!
PS: We will update the default mapper as well
DIGIT_KEY_VAL
setting 'keydisplay' 'harmonic' ? get_key 'pioneer' & param_add 128 : get_key 'pioneer'
geposted Sat 30 Oct 21 @ 2:44 pm
U are right!!!
U are the best!!
Thanks ❤️
U are the best!!
Thanks ❤️
geposted Sat 30 Oct 21 @ 2:55 pm
Omg thank you soo much!! Just stumbled on this Page and been trying to figure this out forever!
geposted Sun 06 Feb 22 @ 9:59 pm
